I copied Telnet Server example from Pack Installer, then build using Keil MDK Pro 7.0, but I have several errors. In Run-time Environment menu, I choose Legacy API. It reduce the errors, but still have some errors.
Which packs are you actually using?
The 'Telnet Server' example pack is show in the Pack Installer when you hover over 'Copy'. What is listed as Pack here?
Maybe the example is based on Middleware 6.5. To select this version use the following in uVision:
- Open from the menu Project - Manage - Run-Time Environment...
- Click on Select Packs and disable Use latest versions of installed Software Packs
- Chose for Pack Keil::MDK-Middleware fixed and select 6.5.0.
Does the example work in this case?
Mr Keil himself got hit by the "let's always change our user name between each post" forum feature :)
The post form really shouldn't ask our name for every post - we aren't expected to change name from post to post.
