I'm getting the following error message when I try to program my STM32 using Keil uVision:
Could not load file BOOT_FLASH.axf"
I've tried toggling the "Verify Code Download" and "Download to Flash" options for the debugger (ST-LINK) but it doesn't fix the problem.
Can anyone help me with this?
Cheers, Tony
Yes, can it find the file? Can you see it in the output directory? Does building report any errors? Do you have the appropriate flash algorithm selected in the debugger options? Is it using a debugger script?
Try checking the .HEX output file generation, and programming with the ST-LINK utilities.
I've fixed this issue. For some reason the axf file was removed from my project folder. I obtained the original axf file from my colleague and can now successfully run my program.
Thanks all the same.
Tony
