Hello:
(So why is there not a MCU architecture/product submission selection for Cortex-M0?)
Well anyway, I just installed KDM5 and did the PACK installer for the cortex-m0 part I'm using, and I successfully copied and ran the blinky example from the Pack.
So I go to do my own hello world example, create the project, add the CMSIS core and startup checkmarks in the run-time environment dialog. I then write my main and build, and get the link error seen here: i.imgur.com/ey7Rvf8.jpg You can also see my run time settings on the overlapping window.
This is apparently due to lack of a startup file, according to my googling. By my estimation I should have a startup file in the device section of the project files, but as you can see, there is no "+" sign at my device item.
First question is, why not, second is how do you force-add one. I found the file I need, I think, deep in the bowels of the Keil file system, but can't find instructions to add it. I would have thought I could right click on the device thing, but that has no add; it must be another way.
Thanks!
They yellow color means that something is missing that it needs to add the checked component. In the bottom it says you need the STM32CubeMX component. Add that for your processor. This is specific to the Brand of processor (ST) and not a generic M0 component.
OK. I thought I went through all the pack stuff to add everything needed. It leaves me having to figure out HOW to get what is needed I guess.
I appreciate your tip. thanks.
