MDK-5.25 Assembler change immediate value of one assembly instruction
I am using the KEIL MDK-5.25, assembly. The project compiles without some problems, but when i see the disassembly the assembler change the inmediate value.
Assembler replace the immediate for another.
ASM code:
                        SBCS    R2,R1                                   ;R2=0xFFFFFFC7
                        SUBS    R2,#0xC7                                ;R2=0xFFFFFF00
                        LSLS    R2,#20                                  ;R2=0xF0000000
Disassembly code:
   517:                         SBCS    R2,R1                                   ;R2=0xFFFFFFC7
0x000006BA 418A      SBCS     r2,r2,r1
   518:                         SUBS    R2,#0xC7                ;R2=0xFFFFFF00
0x000006BC 3A00      SUBS     r2,r2,#0x00
   519:                         LSLS    R2,#20                  ;R2=0xF0000000
0x000006BE 0512      LSLS     r2,r2,#20
   520:                         MOVS    R4,#28
<\pre>
The value #0xC7 replaced to #0x00. And this brings a wrong result.
This only comes when i make the debugger with the microcontroller.
When i use the simulator comes right!!
0x000006BC 3AC7      SUBS     r2,r2,#0xC7
<\pre>
Somebody saw something simlar?
  • Disassembler will read the actual memory contents and decode instructions. Typically you will see the original line as written in the assembler followed by the decoded instruction.
    The simulator shows expected results which indicates that the assembler generated correct code.
    Most likely there is a problem on your target since the memory contents at address 0x000006BC which should be 0x3AC7 is for some reason 0x3A00 (ex: flash programming issue, …).
