I bought an ARM LPC2148 Development board from NXP and started uploading code in it. I wrote the code to blink the on-board 4 LEDs. It gets uploaded successfully in the board but the LEDs never blink (leave alone the blinking according to the code). I have rechecked the code again and again. I am getting 0 V on the pins(P1.16, P1.17, P1.18, P1.19) to which the LEDs are connected. I cannot figure out why this is happening. Help!!
The code is:-
#include <lpc214x.h> //Includes LPC2148 register definitions #define LED1_ON() IO1SET=(1<<16) //Macro Functions to turn ON LED #define LED2_ON() IO1SET=(1<<17) #define LED3_ON() IO1SET=(1<<18) #define LED4_ON() IO1SET=(1<<19) #define LED1_OFF() IO1CLR=(1<<16) //Macro Functions to turn OFF LED #define LED2_OFF() IO1CLR=(1<<17) #define LED3_OFF() IO1CLR=(1<<18) #define LED4_OFF() IO1CLR=(1<<19) void Delay(unsigned char j) //This Function is used to cause delay between LED ON and OFF events { unsigned int i; for(;j>0;j--) { for(i=0; i<60000; i++); } } int main(void) { PINSEL0 = 0x00000000; // Enable GPIO on all pins PINSEL1 = 0x00000000; PINSEL2 = 0x00000000; IO1DIR = (1<<19) | (1<<18) | (1<<17) | (1<<16); // Set P1.16, P1.17, P1.18, P1.19 as Output while(1) { LED1_ON(); Delay(25); LED1_OFF(); LED2_ON(); Delay(25); LED2_OFF(); LED3_ON(); Delay(25); LED3_OFF(); LED4_ON(); Delay(25); LED4_OFF(); } return(0); }
