When I creat a project,it works normally,but if I close the keil later,I can't open the project again.And in the project directory,a *.uvguix.username file can be found.If I delete that file,I can open the project again.So everytime I open it,I have to delete that file first.How can I fix this?
remove the software compatibility
1. Open uVision by selecting the file project.uvprojx
(I assume that you use MDK5 - with older versions it is project.uvproj )
2. If still you face problems open a Support Ticket and:
- attach your project
- a detailed summary
- and the Keil product and version
- as well as the Windows OS in use
Support Ticket: http://www2.keil.com/support/silver
I also recommend to compare with one of the example projects provided by the Pack Installer:
http://www2.keil.com/mdk5/packinstaller/
