Hello!!
I am trying to write a code for interfacing microsd with stm32, but I am unable to compile my code as i'm getting errors which I dont understand. Can you please help me out ?
This is my code :
#include <stm32f10x.h> #include <stm32f10x_rcc.h> #include <stm32f10x_gpio.h> #include <ff.h> #include <diskio.h> #include <xprintf.h> #include <string.h>
int i,j; void msdelay(unsigned int ); void GPIO_Setup(void);
int main() { int buf[]={123,124,125}; UINT* nb; FRESULT fp; GPIO_Setup(); FIL *file;
fp=f_open(file, "NEW.TXT", FA_CREATE_NEW); if(!fp) { fp= f_write(file, buf, sizeof buf, nb); } if(!fp) f_close(file); while(1) { //GPIO_SetBits( GPIOC, GPIO_Pin_14); GPIO_SetBits( GPIOC, GPIO_Pin_13);
msdelay(1000); GPIO_ResetBits( GPIOC, GPIO_Pin_13); msdelay(1000); }
void msdelay(unsigned int value) { unsigned int x,y; for(x=0;x<value;x++) for(y=0;y<1275;y++); }
void GPIO_Setup() { GPIO_InitTypeDef GPIOC_str; RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC , ENABLE); GPIO_DeInit(GPIOB);
GPIO_StructInit( &GPIOC_str); GPIOC_str.GPIO_Speed= GPIO_Speed_2MHz; GPIOC_str.GPIO_Pin= GPIO_Pin_13; GPIOC_str.GPIO_Mode= GPIO_Mode_Out_PP;
GPIO_Init( GPIOC, &GPIOC_str);
and this is the error :
*** Using Compiler 'V5.06 update 4 (build 422)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin' Build target 'Target 1' compiling main.c... .\CMSIS\CM3\DeviceSupport\ST\STM32F10x\stm32f10x.h(8336): warning: #1-D: last line of file ends without a newline /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/ .\CMSIS\CM3\DeviceSupport\ST\STM32F10x\stm32f10x.h(8336): warning: #1-D: last line of file ends without a newline /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/ main.c(21): error: #268: declaration may not appear after executable statement in block FIL *file; main.c(17): warning: #177-D: variable "buf" was declared but never referenced int buf[]={123,124,125}; main.c(18): warning: #177-D: variable "nb" was declared but never referenced UINT* nb; main.c(19): warning: #177-D: variable "fp" was declared but never referenced FRESULT fp; main.c(21): error: #67: expected a "}" FIL *file; main.c(23): error: #77-D: this declaration has no storage class or type specifier fp=f_open(file, "NEW.TXT", FA_CREATE_NEW); main.c(23): error: #59: function call is not allowed in a constant expression fp=f_open(file, "NEW.TXT", FA_CREATE_NEW); main.c(24): error: #169: expected a declaration if(!fp) main.c(29): warning: #12-D: parsing restarts here after previous syntax error f_close(file); main.c(30): error: #169: expected a declaration while(1) main.c(64): warning: At end of source: #12-D: parsing restarts here after previous syntax error main.c: 7 warnings, 6 errors ".\Objects\first.axf" - 6 Error(s), 7 Warning(s). Target not created. Build Time Elapsed: 00:00:02
Did you also have trouble understanding the instructions on how to post source code: www.danlhenry.com/.../keil_code.png
So which errors, exactly, don't you understand?
The secret with error messages is just to read them literally.
They do, of course, assume that you have a good understanding of the language.
Here are some 'C' learning/reference resources: blog.antronics.co.uk/.../
