This is my code for time delay.
.#include<regx51.h> #define led P2 void delay (int i); void main() { while (1) { led = 0x01; delay(500); led = 0x01; delay(500) ; } } void delay (int i) { unsigned int j; for ( i = 0 ; j < i; j++); }
I want to add header file #include "delay.h"
code
.#include<regx51.h> #include "delay.h" #define led P2 void main() { while (1) { led = 0xFF; delay(1000); led = 0x00; delay(500) ; } }
I have gone through this link http://www.keil.com/support/docs/1740.htm This link is not helping much. Please help me with correct source
There is on need to add header files to the project - the compiler will find them automatically via the Include Paths that you specify in your project settings:
http://www.keil.com/support/man/docs/uv4cl/uv4cl_dg_c51.htm
They will then appear as dependencies in the Project window
