With porting me program from SDCC to Keil I got rid of all compiler errors and now I am having me this linker error L250 (CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED) and I do not know what I am doing wrong.
The selected chip is an AT89C51 In the target options I did:
Memory Model Large: variables in XDATA Code Rom Size Large 64K program operating system none
Off- chip code memory start size Eprom 0x0000 0x7FFF
Off chip Xdata memory 0x8000 0x7FFF
My uVision version is 5.24.2.86 toolchain: PK51 Prof, Develpers Kit Version: 9.57.0.0
The real target device is an FPGA which emulates a 80c51 chip. The program itself, a .bin file, is stored on a CF card which the FPGA can run. So in hardware there is no real limitation when it comes to memory size for code and variables. I do have 128 bytes for internal ram to use, but I am not using much of it.
Your original thread was C51, but now you're saying C251 - so which is it??
http://www.keil.com/forum/63381
So it thinks you have the free evaluation version.
See: http://www.keil.com/demo/limits.asp
"PK51 Prof, Develpers Kit Version: 9.57.0.0"
Have you properly entered your licence details?
For help with licence issues, you need to contact Keil support direct.
My uVision was indeed not Licensed. It is now but the problem remains. And I did restart my computer. The linker still throws me fatal error L250.
The linker also claims that the limit is just 0800H bytes.
Did u license it as administrator thicko
Yes I did. I believe you have to. uVision doesn't allow it if the program isn't launched with admin privileges
Also.
I am also having error L6: XDATA SPACE MEMORY OVERLAP alot.
I don't know why this error appears. It is always about 1 address. I don't know if this raises any eyebrows?
My guess is that I have made a mistake in the target options
Yes: that is the limit for the free Evaluation version - see the link provided earlier.
Again, for licensing issues, you need to contact Keil support direct.
See http://www.keil.com/forum/ - the forum is not the route to contact Keil support!
"I am also having error L6"
You should probably get the licensing sorted out before worrying about that.
If you dunno what your eyebrows are doing you shud get someone look tell you thicko.
