I am using MDK-ARM V5.24 and using C++11 for STM32F4. I can compiler and download. Howerver, when I tested on my board, I found that it can't work unless using debug.
In fact, it happends only if I use vector or string class.
So what's the reason caused this? And any ideas?
Best regards.
Please clarify exactly what you mean by that.
Briefly speaking,if I declare a variable(string,vector),no matter whether it is used or not,the program seems to be blocked. I used jlink to debug. I found that the program can't run to the main() and if I used “step over” to make the program run to the main(),it can worked.
