Hi all,
I got a errors : -------------------------------------------------------------------------------------------- "Please preprocess D:\Cantata_Deployment\Keil_30_01\KeilDeployment\cpp_tmp\macros.c with your cross compiler
Save the output as D:\Cantata_Deployment\Keil_30_01\KeilDeployment\cpp_tmp\out.txt
To pre-process a file your compiler will probably need an additional option passed to it. For example, the GCC pre-process only option is "-E" " ---------------------------------------------------------------------------------------------
How to preprocess a source file in Keil Ide. please help me, how to do step by step.
Regards K Srujan kumar
Step by step instructions:
1) .
Nah. I haven't got the time to provide each and every step. Especially when each of those steps must be at a level suitable for someone who might not have been bothered to do any research using their own initiative.
how to preprocess a source file. please let me know any command to preprocess a source file
When you compile the file the compiler does the preprocessing.
calleerlandsson.com/.../
