I have an STTM32F103C8 MCU ("Blue pill") board. What I write to UART1 goes well to he PC. But if I try send data over UART2 only some of the sent characers appear on the PC.
You can see he code below. Is there anyone who knows, what is wrong?
Thanks!
#include "stm32f10x.h" /* function prototypes */ void RCC_Configuration(void); void GPIO_Configuration(void); void USART_Configuration(USART_TypeDef* USARTx); void SysTick_Handler(void); void USART_Send_Char(USART_TypeDef* USARTx, char cData); void USART_Send_CharArray(USART_TypeDef* USARTx, char* Buffer); void USART_Send_Number(USART_TypeDef* USARTx, uint32_t x); int iTick = 0; void delay_us(long usecs); int main(void) { char data; int j=0; char* RXBUFF="testmessage\0"; char* TXBUFF; SystemInit(); RCC_Configuration(); //NVIC_Configuration(); GPIO_Configuration(); USART_Configuration(USART2); USART_Configuration(USART1); //TIM2_Configuration(); // Init SysTick Timer SysTick_Config(1000000); while(1) { delay_us(5000); USART_Send_CharArray(USART1,RXBUFF); USART_Send_Number(USART1,123); delay_us(5000); USART_Send_CharArray(USART2,RXBUFF); USART_Send_Number(USART2,123456789); } } void RCC_Configuration(void) { // Enable GPIOA, GPIOB clock RCC_APB2PeriphClockCmd (RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO , ENABLE); // Enable USARTx clock RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 , ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE); } void SysTick_Handler(void) { iTick = 1; } void GPIO_Configuration(void) { // Initialize Leds mounted on STM32 board GPIO_InitTypeDef GPIO_InitStructure; // Configure the GPIO_LED pin GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); // Configure USART1 Rx (PA10) as input GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); // Configure USART1 Tx (PA9) as alternate function GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); } void USART_Configuration(USART_TypeDef* USARTx) { USART_InitTypeDef USART_InitStructure; /* USART1 configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No ; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USARTx, &USART_InitStructure); USART_Cmd(USARTx, ENABLE); } void USART_Send_Char(USART_TypeDef* USARTx, char cData) { while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); USART_SendData(USARTx, cData); } void USART_Send_CharArray(USART_TypeDef* USARTx, char Buffer[]) { int i=0; while (Buffer[i]) { while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); USART_SendData(USARTx,Buffer[i++]); } } void USART_Send_String(USART_TypeDef* USARTx, const char *str) { while (*str) { while(USART_GetFlagStatus(USARTx, USART_FLAG_TXE) == RESET); USART_SendData(USARTx, *str++); } } void USART_Send_Number(USART_TypeDef* USARTx, uint32_t x) { char value[10]; //a temp array to hold results of conversion int i = 0; //loop index do { value[i++] = (char)(x % 10) + '0'; //convert integer to character x /= 10; } while(x); while(i) //send data { USART_Send_Char(USARTx, value[--i]); } } void delay_us(long usecs) { long i,j; for (i=0;i++ < usecs;) { for (j=0;j++ < 0x12;) { ;} } }
Wait on USARTx not USART1 then... while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
I inserted the lines you suggested like this:
USART_Send_CharArray(USART1,RXBUFF); while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); USART_Send_CharArray(USART2,RXBUFF); while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET);
but there was no change
Your code is broken. You send to two uart but only test the flags for one uart.
I can't really understand: here I send data and check the port, don't I?
//send data to USART1 USART_Send_CharArray(USART1,RXBUFF); //test for USART1 while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); //send to USART2 USART_Send_CharArray(USART2,RXBUFF); //test for USART2 while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET);
Or which code is broken? Can you explain a bit?
