do anyone have experience with BSD socket? I am using LPC1788. What i want to do is to receive a string or data from certain IpAddress with ist port. Example: I want to receive data only from IP: 239,127.0.1 Port 60001 and IP: 239,127.0.2 Port 60002. Look at the code example:
uint8_t uni_ip1[IP4_ADDR_LEN] = {192,168,50,73}; uint8_t mcast_ip1[IP4_ADDR_LEN] = {239,127,0,1}; uint8_t mcast_ip2[IP4_ADDR_LEN] = {239,127,0,2}; void bsd_thread(void const *arg) { SOCKADDR_IN addr; SOCKADDR_IN addr2; SOCKADDR_IN recaddr; int sock,res,addrlen; int sock2; int bind_status; int port_num=1001; char dbuf[200]; char sendebuf[10] = "HELLO"; sock = socket(AF_INET,SOCK_DGRAM,0); printf("sock_status = %i \n", sock); addr.sin_port = htons(port_num); addr.sin_family = PF_INET; addr.sin_addr.s_b1 = uni_ip1[0]; addr.sin_addr.s_b2 = uni_ip1[1]; addr.sin_addr.s_b3 = uni_ip1[2]; addr.sin_addr.s_b4 = uni_ip1[3]; bind_status = bind (sock, (SOCKADDR *)&addr, sizeof(addr)); printf("bind_status = %i \n", bind_status); //Here i start to bind multicast adress with port sock2 = socket(AF_INET,SOCK_DGRAM,0); printf("sock_status2 = %i \n", sock); addr2.sin_port = htons(60001); addr2.sin_family = PF_INET; addr2.sin_addr.s_b1 = mcast_ip1[0]; addr2.sin_addr.s_b2 = mcast_ip1[1]; addr2.sin_addr.s_b3 = mcast_ip1[2]; addr2.sin_addr.s_b4 = mcast_ip1[3]; bind_status = bind (sock2, (SOCKADDR *)&addr2, sizeof(addr2)); printf("bind_status2 = %i \n", bind_status); printf("addr2.sin_port = %i \r\n",ntohs(addr2.sin_port)); printf("addr2[%i . %i . %i . %i], \n",addr2.sin_addr.s_b1,addr2.sin_addr.s_b2,addr2.sin_addr.s_b3,addr2.sin_addr.s_b4); /*Here i join into 2 multicast adresse*/ igmp_join(0,mcast_ip1); igmp_join(0,mcast_ip2); while(1) { while(1) { addrlen = sizeof (addr); res = recvfrom (sock, dbuf, sizeof (dbuf), MSG_DONTWAIT , (SOCKADDR *)&recaddr, &addrlen); printf("recvfrom = %i \r\n", res); if(res >0 ) { printf("receive good \r\n"); printf("%s\n",dbuf); printf("recvfrom = %i \r\n", res); } res = sendto (sock, (char *)&sendebuf, strlen(sendebuf), 0, (SOCKADDR *)&addr, sizeof (addr)); printf("sendto = %i \r\n", res); if (res > 0) { printf("send good \r\n"); } osDelay (100); printf("\n"); break; } } } #define BSDTHREAD_STACKSIZE (1024) osThreadDef (bsd_thread, osPriorityNormal , 1, BSDTHREAD_STACKSIZE);
The Problem is, if i send data to mcast_ip1 port 60001, i get the data, and if i send to ,mcast_ip2 port 60001 I also get the data. Even i only Bind between mcast_ip1 and port 60001. Can anyone help how can i get the data only from mcast_ip1 port 60001 and mcast_ip2 port 60002. Thank you for helps
Best Regards
do anyone have experience with BSD socket? I am using LPC1788. What i want to do is to receive a string or data from certain IpAddress with its port. I want to receive data from two IP-Adress and Port-Number separately: IP: 239,127.0.1 Port 60001 IP: 239,127.0.2 Port 60002 Look at the code example:
to receive from both IP-Multicastaddress, i used the function: igmp_join(0,mcast_ip1); igmp_join(0,mcast_ip2);
The problem is, i receive data from both IP_adress with the port-Number 60001 and it doesn't matter which IP-Adress i used to send data.
Can anyone help how can i get the data only from specific IP-Adress and PORT-Number, Which the Data are sent to. Thank you for help
