I am trying to implement the file system middleware by interfacing a SD card with LPC1768 MCU through SPI bus.But am not able to mound the memory drive as the fmount function returns an error code of fsNoFileSystem.I have formatted the sd card but still it returns teh same error code.What could be the problem ?
Probably try with a different SD Card?
Ok, and what does it read from the one or two sectors that it ends up giving you the fsNoFileSystem message for?
I tried doing that but it is still not able to mount the memory card
It is not reading/writing sectors properly? Validate the SD-SPI layer can perform that basic task correctly.
