Hi Sir,
I am trying to do AND operation with a binary number. I;m little bit confused, here in forums for representation of binary number in keil is 11001100Y but while I'm trying to do the same it ixs showing the error.
I'm using MDK5 the syntax i mentioned is
char a;
a|= 11001100Y;
The error I'm getting is Invalid Suffix on Integer constant.
Does any one please clarify me the issue.
Thanks & Regards Prasanna Kumari
Are you are sure about that?
The uVision Debugger does, indeed, support this:
http://www.keil.com/support/man/docs/uv4/uv4_db_exp_constants.htm
But that is not the same thing at all as saying that any (let alone all) Keil Compiler(s) support it ...
As others have said, it is not a standard 'C' thing; so you might as well learn how to use hex - for the cases where you have to use a compiler without the extension.
Or use the preprocessor to do it in a portable way ...
