I'm using 4 x 4 keypad to send the output to 2 7-segment LED.
problem: key de bouncing problem
Summary problem: when I press key, it shows both digit on the left and right. For example, if I first press 1, it should show 1 on the right and blank on the left. If I press 3 next, it should show 1 on the left and 3 on the right. Right now, it I press 1 it shows 1 on the left and 1 on the right. I think this relate to key debouncing. Please check my code.
void read(void) {
char left_val = 'n';
char right_val = 'n';
char next_val = readKeyPad();
while(1){
if (right_val == next_val || next_val == 'n'){
printChar(left_val, Left);
delay(FRAME_PERIOD);
printChar(right_val, Right);
else {
left_val = right_val;
right_val = next_val;
