stumped with second can channel event.
I have a st32f205 and set up both Can 1&2.
Can 1, will send and receive.
Can 2, will send, not receive.
I can see the data with a tool, so I know the data is on the wire but the ARM_CAN_EVENT_RECEIVE will not pick it up. The ARM_CAN_EVENT_SEND_COMPLETE is working fine.
Here is my can2 had to remove all comments to fit in post. What could I have done wrong?
#define  CAN_CONTROLLER         2
#define _CA_Driver_(n)         Driver_CAN##n
#define  CAN_Driver_(n)        _CAN_Driver_(n)
extern   ARM_DRIVER_CAN         CAN_Driver_(CAN_CONTROLLER);
#define  ptrCAN               (&CAN_Driver_(CAN_CONTROLLER))
uint32_t                        rx1_obj_idx;
uint8_t                         rx1_data[8];
ARM_CAN_MSG_INFO                rx1_msg_info;
uint32_t                        tx1_obj_idx;
uint8_t                         tx1_data[8];
ARM_CAN_MSG_INFO                tx1_msg_info;
static bool sendCompleted = false;
static int ID_Read;
static int _TIMEOUT = 100;
void CAN1_SignalUnitEvent (uint32_t event) {
  switch (event) {
    case ARM_CAN_EVENT_UNIT_ACTIVE:
      break;
    case ARM_CAN_EVENT_UNIT_WARNING:
      break;
    case ARM_CAN_EVENT_UNIT_PASSIVE:
      break;
    case ARM_CAN_EVENT_UNIT_BUS_OFF:
      break;
void CAN1_SignalObjectEvent (uint32_t obj_idx, uint32_t event) {
  if (event == ARM_CAN_EVENT_RECEIVE) {
    if (obj_idx == rx1_obj_idx) {
      ptrCAN->MessageRead(rx1_obj_idx, &rx1_msg_info, rx1_data, 8U);
                        ID_Read = rx1_msg_info.id;
  if (event == ARM_CAN_EVENT_SEND_COMPLETE) {
    if (obj_idx == tx1_obj_idx) {
      sendCompleted=true;
bool CAN1_Initialize (int CAN_BITRATE_NOMINAL) {
  ARM_CAN_CAPABILITIES     can_cap;
  ARM_CAN_OBJ_CAPABILITIES can_obj_cap;
  int32_t                  status;
  uint32_t                 i, num_objects, clock;
  can_cap = ptrCAN->GetCapabilities ();
  num_objects = can_cap.num_objects;
  status = ptrCAN->Initialize    (CAN1_SignalUnitEvent, CAN1_SignalObjectEvent);
  if (status != ARM_DRIVER_OK) { return false; }
  status = ptrCAN->PowerControl  (ARM_POWER_FULL);
  status = ptrCAN->SetMode       (ARM_CAN_MODE_INITIALIZATION);
  clock = ptrCAN->GetClock();
  if ((clock % (8U*CAN_BITRATE_NOMINAL)) == 0U) {
    status = ptrCAN->SetBitrate    (ARM_CAN_BITRATE_NOMINAL,
                                    ARM_CAN_BIT_PROP_SEG  (5U) |
                                    ARM_CAN_BIT_PHASE_SEG1(1U) |
                                    ARM_CAN_BIT_PHASE_SEG2(1U) |
                                    ARM_CAN_BIT_SJW       (1U));
  } else if ((clock % (10U*CAN_BITRATE_NOMINAL)) == 0U) {
                                    ARM_CAN_BIT_PROP_SEG  (7U) |
  } else if ((clock % (12U*CAN_BITRATE_NOMINAL)) == 0U) {
                                    ARM_CAN_BIT_PHASE_SEG1(2U) |
                                    ARM_CAN_BIT_PHASE_SEG2(2U) |
                                    ARM_CAN_BIT_SJW       (2U));
  } else {
    return false;
  rx1_obj_idx = 0xFFFFFFFFU;
  tx1_obj_idx = 0xFFFFFFFFU;
  for (i = 0U; i < num_objects; i++) {
    can_obj_cap = ptrCAN->ObjectGetCapabilities (i);
    if      ((rx1_obj_idx == 0xFFFFFFFFU) && (can_obj_cap.rx == 1U)) { rx1_obj_idx = i;        }
    else if ((tx1_obj_idx == 0xFFFFFFFFU) && (can_obj_cap.tx == 1U)) { tx1_obj_idx = i; break; }
  if ((rx1_obj_idx == 0xFFFFFFFFU) || (tx1_obj_idx == 0xFFFFFFFFU)) { return false; }
  status = ptrCAN->ObjectSetFilter(rx1_obj_idx, ARM_CAN_FILTER_ID_EXACT_ADD, 0xfff, 0U);
  status = ptrCAN->ObjectConfigure(tx1_obj_idx, ARM_CAN_OBJ_TX);
  status = ptrCAN->ObjectConfigure(rx1_obj_idx, ARM_CAN_OBJ_RX);
  status = ptrCAN->SetMode (ARM_CAN_MODE_NORMAL);
  return true;
void setFilters_HS(long ID1, long ID2, long ID3, long ID4, long ID5)
                        ptrCAN->ObjectSetFilter(rx1_obj_idx, ARM_CAN_FILTER_ID_RANGE_REMOVE , 0x100, 0xfff);
                        if (ID1 > 0) ptrCAN->ObjectSetFilter(rx1_obj_idx, ARM_CAN_FILTER_ID_EXACT_ADD, ID1, 0U);
                        if (ID2 > 0) ptrCAN->ObjectSetFilter(rx1_obj_idx, ARM_CAN_FILTER_ID_EXACT_ADD, ID2, 0U);
                        if (ID3 > 0) ptrCAN->ObjectSetFilter(rx1_obj_idx, ARM_CAN_FILTER_ID_EXACT_ADD, ID3, 0U);
                        if (ID4 > 0) ptrCAN->ObjectSetFilter(rx1_obj_idx, ARM_CAN_FILTER_ID_EXACT_ADD, ID4, 0U);
                        if (ID5 > 0) ptrCAN->ObjectSetFilter(rx1_obj_idx, ARM_CAN_FILTER_ID_EXACT_ADD, ID5, 0U);
void CANWrite_HS (int ECU, unsigned char data[])
        sendCompleted=false;
        ID_Read=0;
  memset(&rx1_data, 0U, 8);
  memset(&tx1_msg_info, 0U, sizeof(ARM_CAN_MSG_INFO));
  tx1_msg_info.id = ECU;
        ptrCAN->MessageSend(tx1_obj_idx, &tx1_msg_info, data, 8U);
int CANRead_HS (int ECU, unsigned char data, char position)
        memset(&command_Data, 0U, 8);
        for (int t=0;t <_TIMEOUT;t++)
                osDelay(10);
                if (ID_Read > 0)
                        if (ECU == 0 )
                                memcpy(&command_Data, &rx1_data,8);
                                if (data != 0)
                                        if (command_Data[position] == data) return 1;
                                } else return 1;
                        if (ECU == ID_Read)
                                if (data != 0)
                                } else return 1;
        return 0;
