Hello when i want Using usb host and usb device in a program with lpc1788 , i add usbd_lpc17x_8x & usbh_ohci_177x_8x.c to my project but function usb_irqhandle define in both file how solve this conflict?
maybe you need to choose one of the files to add to your project and leave the other one out.
No all file needs
This has been addressed in latest mw and LPC1700_DFP pack.
For older version you will have to make common IRQ USB Handler that will call Device or Host IRQ handler depending on interrupt that happened.
If you can try latest middleware and latest LPC1700_DFP pack, if not look into drivers in latest LPC1700_DFP pack. Anyways, you will have to make a common USB IRQ handler that will dispatch interrupts to corresponding USB Device or USB Host IRQ handler, depending on interrupt that happened.
I have a Keil 4.7.4 how I can find out which interupt happend?
Correct me if I'm wrong, but doesn't your chip only have one USB unit?
"USB 2.0 full-speed controller that can be configured for either device, Host, or OTG operation with an on-chip PHY for device and Host functions and a dedicated DMA controller."
So shouldn't your program then know what mode the USB unit is currently in, so you know which set of registers to look at for further decisions?
I set first USB devise mode and the second one host and I combine their interrupt (they interrupt happen in same time).. when can I know the interrupt happens does it belong to host or device?
Try downloading and installing last LPC1700_DFP pack from http://www.keil.com/dd2/pack/
and look into drivers for USB to get an idea.
I downloaded Keil.LPC1700_DFP.2.0.0.pack and install it but the question is how can I find that driver location?
c:\Keil\ARM\Pack\Keil\LPC1700_DFP\2.1.0\RTE_Driver\
files: OTG_LPC17xx.c, USBD_LPC17xx.c and USBH_LPC17xx.c
