Hello, i am new to LPC1768 and also in USB development. i want to send some text or textual data from my computer (working as host) to USB device on LPC1768 and vice versa. Please guide me how to start my development. I have read about the USB functionality. I have come to know about the classes that is used for development like Audio, HID etc,
i think that in my case USB CDC is best. Please guide me how to write the CDC Class. I have used the example that come up with LPC1768 but its not connecting with my computer as driver not installed successfully. Please Help me Thanks in advance
If you use Keil example there is Abstract.txt in project explaining how it works and how it can be used.
Thanks for the reply.
yes i am using keil example and i am using USB CDC example but when i connect board with pc. it does not install drivers. Please help me if i am doing something wrong.
You should find your device in device manager, then click on Update Driver and browse to project folder where drivers are, and Windows should then install those drivers.
From driver you mean an .INF file that is in the project folder?
One more question from you. can i use this driver to communicate directly with USB Device instead of making it a virtual com port and send data from UART to USB device. communicate directly means that i want an application running on my PC and sending data to usb port and that data is directly received by USB Device in LPC1768. Please help me i am little bit confused in this.
Your device is mounted by Windows and exposed as an Virtual COM port meaning you from Windows communicate as if it were an UART port, embedded device gets data through USB and the example transfers that to physical UART on embedded device but you can do anything with received data.
Thanks for replying.
i update the driver and give them path to project folder but it gives me error that no drivers found.
i am working on windows 7 64-bit. below i have attached my .inf file. Please help me.
; ; Keil - An ARM Company Comunication Device Class driver installation file ; (C)2007 Copyright ; [Version] Signature="$Windows NT$" Class=Ports ClassGuid={4D36E978-E325-11CE-BFC1-08002BE10318} Provider=%Keil% ;LayoutFile=layout.inf DriverVer=01/06/07 [Manufacturer] %Keil%=DeviceList [DestinationDirs] DefaultDestDir=12 [SourceDisksFiles] [SourceDisksNames] [DeviceList] %DESCRIPTION%=LPC17xxUSB, USB\VID_1FC9&PID_2002 ;------------------------------------------------------------------------------ ; Windows 2000/XP Sections ;------------------------------------------------------------------------------ [LPC17xxUSB.nt] include=mdmcpq.inf CopyFiles=DriverCopyFiles AddReg=LPC17xxUSB.nt.AddReg [DriverCopyFiles] usbser.sys,,,0x20 [LPC17xxUSB.nt.AddReg] HKR,,DevLoader,,*ntkern HKR,,NTMPDriver,,usbser.sys HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropPageProvider" [LPC17xxUSB.nt.Services] include=mdmcpq.inf AddService=usbser, 0x00000002, DriverService [LPC17xxUSB.nt.HW] include=mdmcpq.inf [DriverService] DisplayName=%DESCRIPTION% ServiceType=1 StartType=3 ErrorControl=1 ServiceBinary=%12%\usbser.sys ;------------------------------------------------------------------------------ ; String Definitions ;------------------------------------------------------------------------------ [Strings] NXP="NXP - Founded by Philips" DESCRIPTION="LPC17xx USB VCom Port"
is it support for windows7?? or where is the problem or i am doing something wrong??
I suggest trying latest middleware.
Thank you so much.
Please send me latest package of examples. i have old one. if you have link otherwise please send me latest package on my id. malik_naveed91@yahoo.com
You have latest MDK on Keil website: www.keil.com/.../
