This is a problem that i have posted on the segger forum already and we found out, that this problem seems not to be a segger problem.
Reason: It occurs only if i use the setting "use debug driver" to flash the microcontroller. The segger tools are wroking perfectly.
Now the problem:
I'm using a Jlink Plus, HW V9.10, DLL V5.02h, FW J-Link V9 compiled Oct 9 2015 20:34:47 on Keil MDK-Arm 4.74 and 5.17
Problem: The Debug Adapter fails to erase the second megabyte of the STM32F429 flash. A verify after an erase/program cycle fails. This does not occur when i erase the whole chip!
My Software contains a Bootloader and the real firmware. Both programs are different Keil Projects. The address of the Bootloader is 0x0800_0000 - 0x0800_7FFF.
When i use the Firmware Project, than i won't overwrite the already existing Bootloader. So i have configured the debug Adapter settings inside Keil MDK to use a address range from 0x0800_8000 - 0x081F_FFFF for flash operations.
My second Debug Adapter (Keil ULINK Pro) works perfectly in this Situation!
The Output of the Debug Adapter is:
* JLink Info: Device "STM32F429II" selected.
JLink info: ------------ DLL: V5.02h, compiled Oct 29 2015 19:04:05 Firmware: J-Link V9 compiled Oct 9 2015 20:34:47 Hardware: V9.10 S/N : xxxxxxxxx Feature(s) : RDI, FlashBP, FlashDL, JFlash, GDB
* JLink Info: Found SWD-DP with ID 0x2BA01477 * JLink Info: Found SWD-DP with ID 0x2BA01477 * JLink Info: Found Cortex-M4 r0p1, Little endian. * JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots * JLink Info: CoreSight components: * JLink Info: ROMTbl 0 @ E00FF000 * JLink Info: ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 000BB00C SCS * JLink Info: ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 003BB002 DWT * JLink Info: ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB * JLink Info: ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 003BB001 ITM * JLink Info: ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 000BB9A1 TPIU * JLink Info: ROMTbl 0 [5]: FFF42000, CID: B105900D, PID: 000BB925 ETM ROMTableAddr = 0xE00FF003
Target info: ------------ Device: STM32F429II VTarget = 3.330V State of Pins: TCK: 0, TDI: 1, TDO: 0, TMS: 1, TRES: 1, TRST: 1 Hardware-Breakpoints: 6 Software-Breakpoints: 8192 Watchpoints: 4 JTAG speed: 12000 kHz
Erase Done. Programming Done. Contents mismatch at: 08100000H (Flash=00H Required=80H) ! Contents mismatch at: 08100001H (Flash=20H Required=A0H) ! Contents mismatch at: 08100003H (Flash=00H Required=D3H) ! Contents mismatch at: 08100004H (Flash=00H Required=4AH) ! Contents mismatch at: 08100006H (Flash=00H Required=F3H) ! Contents mismatch at: 08100007H (Flash=23H Required=ABH) ! Contents mismatch at: 08100009H (Flash=00H Required=E1H) ! ... and so on
Thank you Martin
