RTX tiny and radio interrupt of NRF24LE1
Hello to everyone.
I write code for NRF24LE1 using KEIL and rtx tiny. But i have some problems.
When i first create a task and run it, everythink looks good but when i delete it and then created again the task start runs but when call a radio func with radio interrupt never return.
The problem is that i delete the task and then created again maybe but why........;
thanks.
  • It's rather hard to debug source code you aren't allowed to see, given that most people can't even debug their own code they just wrote...
    Does the thread own any locks or other resources when you delete it?
  • Here is my code, the problem is is func "RF_GATEWAYTxString (msgpayload)" , when SUPERVISOR runs and delete and then create FIND_NRF_DEVICES, the func RF_GATEWAYTxString (msgpayload) never returns. And here is all my project
    drive.google.com/folderview
    thanks for answer.
    void find_nrf_devices ()  _task_ FIND_NRF_DEVICES  {
            xdata int id=100;
            xdata int i=0;
            UART_TxString("i START NRF FINDING");
      radio_enable ();        /*RFCKEN = 1U(Enable the radio clock),RF = 1U(Enable RF interrupt)*/
            os_wait (K_TMO, 100, 0);          /* wait for timeout: 100 ticks ~ 1sec   */
                                    do
                                    sprintf(msgpayload,"N%d                         \r\n",id);
                                    msgpayload[31]='\0';
                                    UART_TxString(msgpayload);
                                    if (RF_GATEWAYTxString (msgpayload)==1)
                                            sprintf(uarttxbuffer,"ndevice N%d joined\r\n",id);
                                            UART_TxString(uarttxbuffer);
                                            ndevices_map [i]='1';
                                            os_wait (K_TMO, 100, 0);          /* wait for timeout: 1000 ticks ~ 1sec   */
                                    else
                                            sprintf(uarttxbuffer,"ndevice N%d out of range or closed\r\n",id);
                                            delay_ms(60);
                                            ndevices_map [i]='0';
                                    id++;
                                    i++;
                            }while (id<110);
                            UART_TxString("i CREATE SUPERVISOR");
                            os_create_task (SUPERVISOR);
                            UART_TxString("ndevices_map\r\n");
                            UART_TxString(ndevices_map);
                            UART_TxString("\r\n");
                            UART_TxString(memset(ndevices_map, '0', 100));
                            os_send_signal(SUPERVISOR);
                            while(1)
                                    if (RF_GATEWAYRxString (msgpayload)==1 )
                                    else
    void supervisor () _task_ SUPERVISOR  {
            while(1){
                    os_wait (K_SIG, 0, 0);          /* RTX-51 call: wait for signal         */
                    UART_TxString("i receive signal");
                    os_delete_task (FIND_NRF_DEVICES);\
                    os_create_task (FIND_NRF_DEVICES);/* create task FIND_NRF_DEVICES to find all powered on devices        */
                    while(1)
                    os_delete_task (os_running_task_id ());
    thanks for answer.
            xdata int id=100;
            xdata int i=0;
                                    do
                                    else
                                            delay_ms(60);
                                    id++;
                                    i++;
                            }while (id<110);
                            while(1)
                                    else
            while(1){
                    while(1)
