Good day to everybody!
My device has C8051F340 MCU on board. I have project that is strange. E.g 5 times app starts - on 6th time it doesn't and so on.
Project architecture is Bootloader + App: Bootloader's BLMisc: CODE(0x0-0x05FF, 0xF200-0xF3FF, 0xFA00-0xFBFE, ?CO?FXXX_TARGETBL_INFOBLOCK(0xFBEC))
App's BL51 Misc: CODE(0x0600-0xF1FF, 0xF400-0xF9FF, ?CO?I_SETTINGS(0xF500), ?CO?R_SETTINGS(0xF600), ?CO?FXXX_INFOBLOCK(0xF9E7))
App's C51: INTVECTOR(0x0600) INTERVAL(3)
Keil version V4.14.16.0.
Behavior: I can check leds and control points to understand whether it behaves right or not. The previous version of project works stable. Then I start to remove uncalled functions not changing the logic much. Of course the new map file is linked differently but may be that is why it works bad. I feel that because of settings.
Any ideas? Thanks in advance!
Best regards, Sergey Nelyub
how do you get to the apps interrupts (and reset vector)?
When reset the program enters bootloader and if some conditions are correct (signature check passed) we enter App. In bootloader project modified startup.a51 file I have the interrupts redirection to app:
HW_INTVEC_TABLE EQU 0003h ;HW Interrupt vector table starts here HW_INTVEC_SEPARATION EQU 8 ;HW Interrupt vector separation is 8 Bytes PUBLIC START_APPLICATION ;The entry point (relocated reset vector) START_APPLICATION EQU 0600 ;for the application FW project INTVEC_TABLE EQU START_APPLICATION+3 ;Interrupt vector table starts here INTVEC_SEPARATION EQU 3 ;Interrupt vector separation is 3 Bytes CSEG AT HW_INTVEC_TABLE + (HW_INTVEC_SEPARATION * 0) ;03h (Intr. 00) AJMP INTVEC_TABLE + (INTVEC_SEPARATION * 0) CSEG AT HW_INTVEC_TABLE + (HW_INTVEC_SEPARATION * 1) ;0Bh (Intr. 01) AJMP INTVEC_TABLE + (INTVEC_SEPARATION * 1) // ... CSEG AT HW_INTVEC_TABLE + (HW_INTVEC_SEPARATION * 16) ;83h (Intr. 16) AJMP INTVEC_TABLE + (INTVEC_SEPARATION * 16)
E.g. If timer2 overflows interrupt 5 occurs: Bootloader Addr Code Space: App Addr Code Space: 0x002B->LJMP (0x0603 + (3*5)) ----> LJMP (Timer2_ISR)->Timer2_ISR
OK, when it 'does not start' does the booter start
with the '340 you have full debug, does it always start in debug?
In Bootloader I have the 3 control points too. If the program doesn't start the App for some reason and stays in Bootloader instead I could check them. They should be '0', '1' and toggling correspondingly but they are different. That's why I suggest that the program hasn't started at all in this case.
I have several dozens of identical devices that I switch on at once. So it's rather difficult to 'catch the bug' in the debug mode because it's unclear what device will misbehave. I could only connect USB Debug Adapter to one of them.
