Hello Everyone, I am working in following environment,
IDE-Version: µVision V5.22.0.0 Tool Version Numbers: Toolchain: MDK-ARM Cortex-M0/M0+ 256K for ST Version: 5.22
We have a custom board with centered MCU STM32F070RBTx. This is not an example code, my company made it before, I need to mordarate it. This code was build in Coo-cox environment, I have modified some of its part after changing its main MCU pinout in cubemx.
In pre processor setting, its written -c --cpu Cortex-M0 -D__RTX -g -O3 --apcs=interwork --split_sections --asm --interleave --asm_dir ".\\" -I ../Inc -I ../Drivers/STM32F0xx_HAL_Driver/Inc -I I am using --C99 control, not C99 mode.
After setting things in mdk-keil, I am having the following ,
1.One very unknown sign appears in my main.c, at condition, if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK), The system says," implicit declaration of function HAL_RCC_OscConfig that is invalid in C99"
2. ../Drivers/STM32F0xx_HAL_Driver/Inc/stm32f0xx_hal_rcc_ex.h(2051): error: #20: identifier "HAL_StatusTypeDef" is undefined....what kind of error is it? should I have to define HAL_StatusTypeDef any other place ?
3. ../Drivers/STM32F0xx_HAL_Driver/Inc/stm32f0xx_hal_i2c.h(216): error: #90: function returning function is not allowed.....kindly tell me why this is coming?
4. I have tried to change /*#define HAL_DMA_MODULE_ENABLED, but still build error log says,
../Drivers/STM32F0xx_HAL_Driver/Inc/stm32f0xx_hal_dma.h(134): error: #20: identifier "HAL_LockTypeDef" is undefined
Seems like all errors coming from HAL driver that is automatically generate in MDK keil or those typical errors are coming from mismatching of cubemx code and mxcontants.h. I was trying to look up the settings in stm32f0xx_hal_conf.h, activate and inactivated some HAL_MODULE, seems like these are conflicting with other constant exists elsewhere.
Help me please.
Regards Hasan
Did you find a solution to this?
I am having the same issue here and I am not sure how to solve it.
Would you please care to elaborate what all issues you are having and what is the background of your project?
Take a look these link, you will understand what I wanted to implement.
1. Basic idea I did ask, community.st.com/.../31789 2. Should I use RTC or not ,community.st.com/.../31919 3 Complexity in BCD, community.st.com/.../31923 4. Confusion about DMA, community.st.com/.../31917 5. Reading temperature senors, community.st.com/.../32145 6. Uniqueness of SPI, community.st.com/.../32175 7. Problems in compiler, community.st.com/.../32459 8. Hard to tract down actual cases, community.st.com/.../32323
9. Confusion, community.st.com/.../34449-corrected-clock-setting-from-cubemx
