Using µVision V5.24.2.0 with ULinkPro V1.58 on target LPC1343 (Cortex-M3, 72 MHz) via SW. Event Viewer always stops with message "Timestap Error!". Tried all Timestamp Prescaler (1, 4, 16, 64) no success. Tried different SW Max. Clocks (1, 10, 50 MHz) , no success. Tried SWJ checkbox on and off, no success. Tried "Clear" in Event Viewer window. After about 5 secs Timestamp Error appears again.
Is there any Suggestion for Debug and/or UlinkPro Settings which should be used?
Bets Regards Juergn.
as written here www.keil.com/.../uv4_db_dbg_event_viewer.htm , first of all you should make sure your SWO trace works fine without any error shown in the trace status bar: www.keil.com/.../ulinkpro_trace_status.htm
