problem building bootloader compatible HEX/BIN files...
I have a board with a SPI flash chip on it, and via a UART it can receive a BIN file plus
metadata and write it to the SPI flash chip. This is all done with an app that starts at
the 2nd sector of MCU flash (it's this same code that uses the UART to download apps for the
bootstrap loader), and I have another app, a bootloader, that uses IAP calls to sector by
sector erase/copy the BIN part of the app in SPI flash to MCU flash and then branch to this
'downloaded' app, and it runs fine, but *only* if I manually strip the beginning of the
BIN file out before downloading it via the UART and getting it into the SPI flash chip.
This beginning is 0x1D00 0xFF's, and after that is the code that loads the SP and branches
around all the INT vectors to the startup code.
I use the project's linker options and specify to use the memory layout from Target Dialog,
and specify my app start address (0x2000) and configure the start/size of the address range
in the debugger flash download dialog similarly.
The problem I have is that when I take my HEX file and convert it to a BIN file it has
0xFF's from address 0 to 0x1D00, and the next 8 bytes are what I expected at the RESET vector
to load the SP and then jump past all the INT vectors to where the RESET startup code is.
So, if I copy this BIN file (plus metadata) to my SPI flash and reboot, and let the bootstrap
loader get the BIN file into MCU flash at 0x2000 and then branch there it crashes. However,
if I post-process the BIN file to strip out all the leading 0xFF's up to 0x1D00 and then get
that into my SPI flash, then when the MCU is reset and the bootloader copies the file to
0x2000 and branches to it everything works fine.
So... what I can't figure out is (1) where these 0x1D00 0xFF's are coming from and ending up
in the beginning of my HEX/BIN files; and (2) how to get my app to build without them. Google
has not been very helpful in helping me resolve this.
FWIW, my MCU is an LPC1752.
Help...
Dave
