Prior to updating from Keil Version 4.72a to Keil Version 5.15, the Event Viewer, System and Thread Viewer, Memory and Watch Windows used to update in real time while the debugger was running with the Serial Wire Trace using the ULINK Pro. I still get the system notification Trace:Running... and when stopping the code execution the system view windows above will update to the last state, however they will not update real time, nor will the elapsed time (t0) update real time as it used to.
I left 4.72a installed, and now using this IDE, it also will not run in debug mode real time.
I've changed none of the project settings... only did the upgrade.
I found this functionality extremely useful and would like to get it back. Does anyone have any ideas what may have caused this change or where I can look.
Hi Jeremy,
when you are in Debug-mode have a look under the "View"-Tab...is the option "Periodic Window Update" checked?
Regards, Niclas
This was it... submitted a case to Keil and they provided that solution as well.
Thanks for your help!
Jeremy
