How to reduce noise in hardware design
My question in a general question about reducing noise in a hardware design.
Is there a guideline to follow in order to reduce effect of external noise such as electropump or electric valve which is driven by an MCU using a relay?
I am using STM32L152VD LQFP100 running with 16MHz internal oscillator. one of the serious things I see is effect of main power plugin to keypad input of MCU such that it is like a button is pushed when I plug in the 220V switching adapter power.
Next is when MCU controls an electric valve in start or stop moment such that it is like a button is pushed.
I have used same capacitor and resistor as in discovery board used for push button and used EMI ferrit filter around input power (5V) to my board. I used ferrit bead in series with main VCC of the board. should I used ferrit bead for all interrupt input and all VCC pins of the MCU? is there any other advice like a specific filter?
