Reading GPIO_IDR assembly
Hello, I am using a discovery board with an STM32l152. The user push button is ported to PA0. I need to read from the IDR bit on the GPIOA when the button is pushed. I read that it can only be accessed via word only. I have already set up the moder, otyper, etc correctly and checked it against the debugger. Below is the offset address of GPIOA_IDR.
   LDR r0, =0x40000000 ;PERIPH_BASE
   ADD r0, #0x20000      ;AHBPERIPH_BASE
   ADD r0, #0x0400               ;GPIOA_BASE
   ADD r0, #0x10
   if((GPIOA-IDR & 0x1) == 1) turn on LED
I would like to do the the C statement above in assembly. Thank you very much
  •   LDR r0, =0x40000000 ;PERIPH_BASE
       ADD r0, #0x10
    Note that there are way more efficient ways to get the address of the register.
    Maybe you should spend some time looking at the code that the Keil compiler generates, with the processor instruction set document as cross-reference.
    The documentation tells what an instruction does, while the compiler output will give an indication of how you use the instructions practically.
       ADD r0, #0x10
