identical compiles produce different size images
our units use dual images for upgrade safety which only differ in address locations.
each image uses the same source with project files (.uvproj) that only change the scatter
file used for linking. When doing a full compile of each image I've recently started
noticing that the images differ by 4 bytes. This appears to happen during linking and compiling on one of our other systems doesn't produce this issue so I suspect something has
been corrupted on my laptop.
This is very disconcerting.
Any ideas??
