I am currently doing a project and wanted a workaround to read in data from files to char arrays like the fopen function does in C for example. I am not allowed to use the CAN Bus and thus have to do a workaround.
If somebody happens to know what I should start looking after or has some ideas please feel free to share it with me, thank you in advance!
Keil does offer a file system designed for 16-bit devices, inside the Advanced RTX-166: http://www.keil.com/c166/ar166/
You may want to check if your device is in the supported list. Their product team can help show how to evaluate the RTOS: http://www.keil.com/product/contact.asp
Where is the file stored, in the first place?
Thanks for the advice I will try that out.
The file is located on the pc which is connected through the ASC0 of the C167.
The nearest thing to your setup would be the File_ex1 example, solely because it uses a serial interface. The product team offers trial PSN's, at their discretion: You'll want to download a ARTX update: http://www.keil.com/update/ar166.asp to get access to the File_ex1 example.
The example stores input from the serial interface into a file stored in SRAM, rather than taking data from a file on the PC to an array of char's. The File_ex1 example could only be used as an example of the interface.
Anyways, you don't even need a file system on the microcontroller, for what you are trying to do. Just output the file data over a serial interface from the PC: stackoverflow.com/.../how-to-send-file-over-serial-port-in-windows-command-prompt via some kind of trigger.
Then transfer data from peripheral buffer to the array of chars.
A file system helps: --increase robustness for larger data transfers, --(with flash) store data, in non-volatile memory, to add some protection to data (ex. during a power loss), --store used data and remove unused data in a very organized way, and --provide easy compatibility for data transfers back to the PC, at least, when compared to multiple arrays of chars.
thank you for all your help in the first place. I will try these things out thanks for answering!
