My MCU architecture is ARM968 and I found some hint about how to configure the RTX_Config.c in www.keil.com/.../rlarm_ar_advconfig_cfgmac.htm.
There is a tricky problem in my MCU that I can't configure the OS_TREL(), because my MCU haven't STIR(Software Trigger Interrupt Register). However, I found a macro __OS_TMR_FORCE_IRQ in RTX_lib.c. It seems I don't need configure the OS_TREL() if I define it.
Can anyone tell me everything be OK if I do define it?
I am utilizing Keil uVision rendition 5.40. I stack the application in my objective board utilizing
Keil ULINK2 Debugger. I can bounce to my startup code. When I get to the accompanying direction:
bx __main()
I can't single stride into Keil's __main(). When I have a go at venturing into it, code begins running.
When I hit stop execution, I wind up in the accompanying filename (RT_Agent.c):
void _sys_exit (int return_code) {
/* Endless circle. */
while (1);
www.bestessaywritingservice.co/
Thanks for your simulation! Could you tell me what architecture you used and it will be different phenomenon that use normal way, define OS_TFIRQ(), to run same program?
