I am struggling with getting the compiler set up correctly and was wondering if anyone could please help.
Our circuit uses an external flash memory configured for paging. All I am trying to do is get the blinky example code to run. I have compiled it sucessfully, no errors or warnings and I have compared the machine code output with what is in the flash buffer and it corrolates ok, but when I put the chip in the board it doesn't run the code.
The same code copied into a project created by a previous engineer works fine, but I need to start a new project and don't seem to be able to get this to work.
Hi, has anyone got any ideas on this at all? I am really stumped. I can get my code running by loading the hex file from a previous project and then overwriting the "Main" function, so I know my code is good, but the compiler refuses to create a hex file that will operate correctly.
Sorry, should have said I am using uVision V3.31
