I am using uVision 5.15 processor is emf32g222f128. my code(part of bootloader based on silicon lab supplied code) is:
oid BOOT_jump(uint32_t sp, uint32_t pc) { /* Set new MSP, PSP based on SP (r0)*/ __asm("msr msp, r0"); __asm("msr psp, r0"); //goto *Default_PC; /* Jump to PC (r1)*/ __asm("mov pc, r1"); }
causes compiler errors:
compiling Bootloader.c... Bootloader.c(153): warning: #1267-D: Implicit physical register R0 should be defined as a variable __asm("msr msp, r0"); Bootloader.c(153): error: #549: variable "R0" is used before its value is set __asm("msr msp, r0"); Bootloader.c(157): warning: #1267-D: Implicit physical register R1 should be defined as a variable __asm("mov pc, r1"); Bootloader.c(157): error: #549: variable "R1" is used before its value is set __asm("mov pc, r1"); Bootloader.c: 2 warnings, 2 errors
I have tried several variations. msr msp r0 works fine but not the "mov pc, r1" Any ideas?
Yash
