i have interfaced Nand flash to lpc1788,and it is working fine,now i have to add USB flash drive to LPC1788, i have done the configuration settings for usb flash,and now usb initialised successfully, but when i am trying to write the file nand flash, file added to nand flash drive, but after nand flash read /write operation ,my usb drive not working,i dnt understand why it is not working ??
Please help me ,can i interface usb flash drive and nand flash drive on same controller ???if yes,is there any settings or any changes needs to be required for both flash drive ,give me suggestion???
Someone,please could me help me out ????because i am stuck up in my project with this situation..
Not single reply ....feeling sad...but finally i found the solution and m glad to tell that my problem is solved and i can interface both the drive simultaneously,both are working fine.
( Your topic is too difficult for me. ) Congratulation!
