Dear friends,
I've got this weird problem with the USB controller on LPC1788. I use RL-USB to do the job. I initialize the RL-FlashFS file system on the USB and I create a text file and simply write "Hello World!" in this text file using fputs function. This is the main function of my application:
int __test = 0x55; int main() { FILE* txtFile; __test = finit("U0:"); if (__test) while(1); txtFile = fopen("U0:test1.txt", "w"); if (txtFile != NULL) fputs("Hello World!", txtFile); fclose(txtFile); while(1) funinit("U0:"); }
so far so good. Everything works fine, the file is created and the string is written to it (I see it in the debugger). The strange thing is that when I connect the flash memory to my computer, there is no such a text filet as test1.txt in it.
Even stranger is that when I reconnect this flash memory to my own hardware and try to read test1.txt, using fgetc() function, it is read just fine and the string "Hello World!" is returned.
I really have no idea what is going on. If you have any experiences about this please share it with me.
Regards
If you are using latest middleware can you try sequence from documentation www.keil.com/.../group__system__routines.html
so - finit - fmount - write file - funmount - funinit
BTW why are you doing funinit endlessly in while loop?
Also it seems that you haven't initialized USB Host at all.
Why don't you try existing example for Embedded Artists LPC1788 board for reference.
Install latest LPC1700_DFP v2.1.0 and in folder: c:\Keil\ARM\Pack\Keil\LPC1700_DFP\2.1.0\Boards\Embedded Artists\LPC1788-32 Developers Kit\Middleware\USB\Host\MassStorage\
there is the before-mentioned example.
