Dear friends,
I've got this weird problem with the USB controller on LPC1788. I use RL-USB to do the job. I initialize the RL-FlashFS file system on the USB and I create a text file and simply write "Hello World!" in this text file using fputs function. This is the main function of my application:
int __test = 0x55; int main() { FILE* txtFile; __test = finit("U0:"); if (__test) while(1); txtFile = fopen("U0:test1.txt", "w"); if (txtFile != NULL) fputs("Hello World!", txtFile); fclose(txtFile); while(1) funinit("U0:"); }
so far so good. Everything works fine, the file is created and the string is written to it (I see it in the debugger). The strange thing is that when I connect the flash memory to my computer, there is no such a text filet as test1.txt in it.
Even stranger is that when I reconnect this flash memory to my own hardware and try to read test1.txt, using fgetc() function, it is read just fine and the string "Hello World!" is returned.
I really have no idea what is going on. If you have any experiences about this please share it with me.
Regards
