hello dear all, I have a problem in showing hex packet on LCD.I send a hex file by UART and i want to show it on LCD. but LCD show different number. like : i send 02 but it show 202. I taught maybe it's because of baud rate but it isn't work still. could you tell me what's the problem? i use keil and my ARM is LPC1768
#include <LPC17xx.H> definitions #include "LCD.h" #include "string.h" #include "sys.h" #include "lcd.h" #include "touch.h" #include "exti.h" #include <stdio.h> #include "uart.h" unsigned char lcd_buf[50]; unsigned char s[10]; void Delay (uint32_t Time) { uint32_t i; i = 0; while (Time--) { for (i = 0; i < 5000; i++); } } /* ********************************************************************************************************* * Description: The function is setting font colors¡¢brush colors and the area of clear * Arguments : None * Returns : None ********************************************************************************************************* */ void Load_Drow_Dialog(void) { LCD_Clear(WHITE); POINT_COLOR=Red; //Setting font colors LCD_ShowString(216,0,"txt"); //Displaying screen clear area POINT_COLOR=BLUE; //Setting brush color } /* ********************************************************************************************************* * Description: Main function * Arguments : None * Returns : None ********************************************************************************************************* */ int main (void) { int i=0; int j=0; SystemInit(); LCD_Init(); Load_Drow_Dialog(); UART2_Init(); while(1){ for(i=0;i<7;i++){ s[i]=UART2_GetChar()-190; } sprintf(lcd_buf,"%d-%d-%d-%d",s[3],s[4],s[5],s[6]); LCD_ShowString(40,60,lcd_buf ); Delay(4000); } }
is it possible, because of clk or work frequency? i just know a Little about it.
part of system init for clock:
*---------------------------------------------------------------------------- Clock Variable definitions *----------------------------------------------------------------------------*/ uint32_t SystemCoreClock = __CORE_CLK;/*!< System Clock Frequency (Core Clock)*/ /*---------------------------------------------------------------------------- Clock functions *----------------------------------------------------------------------------*/ void SystemCoreClockUpdate (void) /* Get Core Clock Frequency */ { /* Determine clock frequency according to clock register values */ if (((LPC_SC->PLL0STAT >> 24) & 3) == 3) { /* If PLL0 enabled and connected */ switch (LPC_SC->CLKSRCSEL & 0x03) { case 0: /* Int. RC oscillator => PLL0 */ case 3: /* Reserved, default to Int. RC */ SystemCoreClock = (IRC_OSC * ((2ULL * ((LPC_SC->PLL0STAT & 0x7FFF) + 1))) / (((LPC_SC->PLL0STAT >> 16) & 0xFF) + 1) / ((LPC_SC->CCLKCFG & 0xFF)+ 1)); break; case 1: /* Main oscillator => PLL0 */ SystemCoreClock = (OSC_CLK * ((2ULL * ((LPC_SC->PLL0STAT & 0x7FFF) + 1))) / (((LPC_SC->PLL0STAT >> 16) & 0xFF) + 1) / ((LPC_SC->CCLKCFG & 0xFF)+ 1)); break; case 2: /* RTC oscillator => PLL0 */ SystemCoreClock = (RTC_CLK * ((2ULL * ((LPC_SC->PLL0STAT & 0x7FFF) + 1))) / (((LPC_SC->PLL0STAT >> 16) & 0xFF) + 1) / ((LPC_SC->CCLKCFG & 0xFF)+ 1)); break; } } else { switch (LPC_SC->CLKSRCSEL & 0x03) { case 0: /* Int. RC oscillator => PLL0 */ case 3: /* Reserved, default to Int. RC */ SystemCoreClock = IRC_OSC / ((LPC_SC->CCLKCFG & 0xFF)+ 1); break; case 1: /* Main oscillator => PLL0 */ SystemCoreClock = OSC_CLK / ((LPC_SC->CCLKCFG & 0xFF)+ 1); break; case 2: /* RTC oscillator => PLL0 */ SystemCoreClock = RTC_CLK / ((LPC_SC->CCLKCFG & 0xFF)+ 1); break; } } } /** * Initialize the system * * @param none * @return none * * @brief Setup the microcontroller system. * Initialize the System. */ void SystemInit (void) { #if (CLOCK_SETUP) /* Clock Setup */ LPC_SC->SCS = SCS_Val; if (SCS_Val & (1 << 5)) { /* If Main Oscillator is enabled */ while ((LPC_SC->SCS & (1<<6)) == 0);/* Wait for Oscillator to be ready */ } LPC_SC->CCLKCFG = CCLKCFG_Val; /* Setup Clock Divider */ LPC_SC->PCLKSEL0 = PCLKSEL0_Val; /* Peripheral Clock Selection */ LPC_SC->PCLKSEL1 = PCLKSEL1_Val; LPC_SC->CLKSRCSEL = CLKSRCSEL_Val; /* Select Clock Source for PLL0 */ #if (PLL0_SETUP) LPC_SC->PLL0CFG = PLL0CFG_Val; /* configure PLL0 */ LPC_SC->PLL0FEED = 0xAA; LPC_SC->PLL0FEED = 0x55; LPC_SC->PLL0CON = 0x01; /* PLL0 Enable */ LPC_SC->PLL0FEED = 0xAA; LPC_SC->PLL0FEED = 0x55; while (!(LPC_SC->PLL0STAT & (1<<26)));/* Wait for PLOCK0 */ LPC_SC->PLL0CON = 0x03; /* PLL0 Enable & Connect */ LPC_SC->PLL0FEED = 0xAA; LPC_SC->PLL0FEED = 0x55; while (!(LPC_SC->PLL0STAT & ((1<<25) | (1<<24))));/* Wait for PLLC0_STAT & PLLE0_STAT */ #endif #if (PLL1_SETUP) LPC_SC->PLL1CFG = PLL1CFG_Val; LPC_SC->PLL1FEED = 0xAA; LPC_SC->PLL1FEED = 0x55; LPC_SC->PLL1CON = 0x01; /* PLL1 Enable */ LPC_SC->PLL1FEED = 0xAA; LPC_SC->PLL1FEED = 0x55; while (!(LPC_SC->PLL1STAT & (1<<10)));/* Wait for PLOCK1 */ LPC_SC->PLL1CON = 0x03; /* PLL1 Enable & Connect */ LPC_SC->PLL1FEED = 0xAA; LPC_SC->PLL1FEED = 0x55; while (!(LPC_SC->PLL1STAT & ((1<< 9) | (1<< 8))));/* Wait for PLLC1_STAT & PLLE1_STAT */ #else LPC_SC->USBCLKCFG = USBCLKCFG_Val; /* Setup USB Clock Divider */ #endif LPC_SC->PCONP = PCONP_Val; /* Power Control for Peripherals */ LPC_SC->CLKOUTCFG = CLKOUTCFG_Val; /* Clock Output Configuration */ #endif #if (FLASH_SETUP == 1) /* Flash Accelerator Setup */ LPC_SC->FLASHCFG = (LPC_SC->FLASHCFG & ~0x0000F000) | FLASHCFG_Val; #endif }
You claim you send hexadecimal data.
The only time it would be meaningful to talk about hexadecimal data would be if you send it as ASCII characters '0'..'9', 'A'..'F' (or lower-case 'a'..'f').
But why do you then subtract 190 from every received character?
actually, i tried to check that any of my numbers sum to 190 but it wasn't,it just show random number. i forgot to erase this part. i just write UART2_GetChar().
in addition, LCD and UART in a separate code work correctly, but when use two codes it doesn't work.
