uni-ds3 LPC2148 MCU with ULINK2 Config. Fails
Hello ,
my SW Environment is
-uvision 5
My HW Environment is
-Development Board : UNI-DS3 based on LPC2148 Board from MicroElectronika
-ULINK2 JTAG adapter from Keil
My HW Setup :
1- placing Jumpers J1-J7 to JTAG position in MCU card
**MikroElectronika mentions nothing else
My SW configuration :
1- options for Target -> Debug -> Use :ULINK2/ME ARM Debugger settings ->MAX JTAG Clock = 50KHZ
(i used different High/low speed ,no effect)
2- -> use nTRST
3- -> use cache options
4- -> Verify Code Download
5- -> Chain: Manual Configuration (IDCODE ,Device Name , IR len)=(0x0F1F0F0F0 , ARM7TDMI-S Core , 4)
(i used automatic detection , gives me : "NO JTAG Devices Found" )
should it be two chains or just one chain of arm core?
6- -> Utilities -> Use Target Driver for Flash Programming
7- -> use Debug Driver
8- ->settings -> i used default settings for programming algorithm
9- -> check program/verify/Reset and Run
So , step 8,9 is the real actions of FLASHING not step 4 ?
** i followed ULINK2 User Guide
** some other tutorial settings
Result of these settings when press debug :
Could Not Stop ARM Device , please check JTAG Cable
What could be wrong settings
Is there Semi-agreed Debug settings for supported processors and MCUs
i'm afraid it's HW problem between JTAG and JTAG module in MCU (signal incompatibility, missing Component,...)
i would not be able to solve HW problems if Exist
Thanks and Regards ,
