C++ iostream error. Undefined symbols from ios.o
I try to compile some C++ code with <iostream> included.
Build output:
.\DEBUG.axf: Error: L6218E: Undefined symbol __fread_bytes_avail (referred from ios.o).
.\DEBUG.axf: Error: L6218E: Undefined symbol mbsinit (referred from ios.o).
.\DEBUG.axf: Error: L6218E: Undefined symbol wmemmove (referred from ios.o).
Somebody said:
It's because microLib does not implement full set of features as ARM library (C standard library).
On infocenter.arm.com/.../index.jsp written:
The default version of __fread_bytes_avail() fills a buffer by calling fgetc() until either the buffer is filled or EOF is encountered.
This means default version exists and implemented. But it is not.
Issue is not new:
stackoverflow.com/.../iostream-keil-c-problems
developer.mbed.org/.../ST-Nucleo-L152RE-SDCard
While writing this post I've solved problem:
#ifdef __MICROLIB /*__CC_ARM*/
/// To suppress MDK-ARM Linker Error: L6218E: Undefined symbol __fread_bytes_avail (referred from ios.o).
size_t __fread_bytes_avail(void * __restrict ptr,
                    size_t count, FILE * __restrict stream) //__attribute__((__nonnull__(1,3)))
        return -1;
#include <wchar.h>
/// To suppress MDK-ARM Linker Error: L6218E: Undefined symbol mbsinit (referred from ios.o).
int mbsinit(const mbstate_t * ps)
        return -1;
wchar_t *wmemmove(wchar_t * __restrict s1,
                      const wchar_t * __restrict s2, size_t n) //__attribute__((__nonnull__(1,2)))
        return NULL;
#endif /*__MICROLIB*/ /*__CC_ARM*/
If your program will use this functions, they should be implemented properly. Look at open source stdlib implementations on the internet.
