I have problem about location of local variable in data memory. In my code void WRITE_RTC(uchar Dat,uchar Addr) { xxx=(RTC_ADDR|WRITE); Start(); Out_Byte(xxx); Out_Byte(Addr); Out_Byte(Dat); Stop(); } but in M51 file it show TYPE BASE LENGTH RELOCATION SEGMENT NAME DATA 0074H 0002H UNIT ?DT?_WRITE_RTC?I2C_DEVICE_FUNCTION3 in function I have only local variable uchar Dat,uchar Addr why keil fix address for them
Note that the beginning of the 2nd paragraph in that link directly answers your original question: "Normally, functions in Cx51 cannot be called recursively or in a fashion which causes reentrancy. The reason for this limitation is that function arguments and local variables are stored in fixed memory locations." Unless you absolutely need your functions to be reentrant, do not specify the 'reentrant' attribute. As it says in the link, that will make your code grossly inefficient!
"why keil fix address for them" You can specify that the compiler not use fixed addresses if you wish. See http://www.keil.com/support/man/docs/c51/c51_le_reentrantfuncs.htm
Obviously another PC programmer who is used to having a huge stack available for storing local variables...
"why keil fix address for them?" Why not! Take a look at the description of the calling convention & parameter passing rules in the C51 Manual
