8051 - I2C BitBang
Im using I2C bitbang and Im facing an issue. I think I need a delay between SCL and SDA lines. Im not sure how much the delay needs to be.
Can someone check my I2C code to see if everything checks out? I want to make sure its not a software mistake.
#include <at89c51ic2.h>
#include <stdio.h>
#define SDA P0_0
#define SCL P0_1
void I2CInit(){
        SDA = 1;
        SCL = 1;
void I2CStart(){
        SCL = 1;
        I2CDelay();
        SDA = 0;
        I2CDelay();
        SCL = 0;
        I2CDelay();
void I2CRestart(){
        SDA = 1;
        SCL = 1;
        SDA = 0;
        SCL = 0;
void I2CStop(){
        SDA = 0;
        I2CDelay();
        SCL = 1;
        I2CDelay();
        SDA = 1;
        I2CDelay();
void I2CAck(){
        I2CDelay();
        SDA = 0;
        I2CDelay();
        SCL = 1;
        I2CDelay();
        SCL = 0;
        I2CDelay();
        SDA = 1;
        I2CDelay();
void I2CNak(){
        SDA = 1;
        SCL = 1;
        SCL = 0;
        SDA = 1;
void I2CSend(unsigned char Data){
        unsigned char i;
        for (i = 0; i < 8; i++) {
                if ((Data & 0x80) == 0)
                        SDA = 0;
                else
                        SDA = 1;
                SCL = 1;
                I2CDelay();
                SCL = 0;
                I2CDelay();
                Data <<= 1;
        SDA = 1;
        I2CDelay();
        SCL = 1;
        I2CDelay();
        if (SDA)
                SCL = 0;
        I2CDelay();
        SDA = 1;
        SCL = 1;
char I2CRead(unsigned char lastone){ // last one == 1 for last byte; 0 for any other byte
        char i, Data=0;
        for (i = 0; i < 8; i++){
                SCL = 1;
                I2CDelay();
                if(SDA) Data |=1;
                if(i<7) Data<<=1;
                SCL = 0;
                I2CDelay();
        SDA = lastone;
        SCL = 1;
        I2CDelay();
        SCL = 0;
        SDA = 1;
        SCL = 1;
        I2CDelay();
        return Data;
void I2CSendAddr(unsigned char addr, unsigned char rd){
        I2CStart();
        I2CSend(addr+rd);
void I2CDelay(){
        unsigned int i;
        for (i = 0; i < 4000; i++);
        return;
