hi, guys I have a doubt regarding interfacing lcd to arm7. I have an lpc2148 development board. This board did have a lcd interfacing example. I also have another program I got from internet. I see that the function to initialize the lcd are written in different ways in both the examples. In the example I got with the board the "void lcd_init()" is little complex. But the other example I got from internet the has "void init_lcd( void )" written in a simple way. I have edited and tried the codes in different ways and I see only the code I received with the board works. I am new to ARM, but I don't think this should be correct, we should be able to make new codes. Hoping someone can understand my doubt.
CODE THAT CAME WITH THE DEVELOPMENT BOARD
#include <LPC214x.H> #define LCD_RS (1<<10) #define LCD_RW (1<<12) #define LCD_EN (1<<13) #define LCD_D4 (1<<20) #define LCD_D5 (1<<21) #define LCD_D6 (1<<22) #define LCD_D7 (1<<23) #define LCD_DATA_MASK (LCD_D7|LCD_D6|LCD_D5|LCD_D4) #define LCD_IOALL_MASK (LCD_D7|LCD_D6|LCD_D5|LCD_D4|LCD_RS|LCD_EN|LCD_RW) //*************************** void enable_lcd(void) { unsigned int i; IOSET0 = LCD_EN; for (i=0;i<400000;i++); IOCLR0 = LCD_EN; } //************************** void lcd_init() { unsigned int i; PINSEL1 = 0x00000000; IODIR0 |= LCD_IOALL_MASK; for (i=0;i<1000;i++); IOCLR0 = (LCD_IOALL_MASK); IOSET0 = (LCD_D5|LCD_D4); enable_lcd(); for (i=0;i<100;i++); IOCLR0 = (LCD_IOALL_MASK); IOSET0 = (LCD_D5|LCD_D4); enable_lcd(); for (i=0;i<100;i++); IOCLR0 = (LCD_IOALL_MASK); IOSET0 = (LCD_D5|LCD_D4); enable_lcd(); delay(10000); while(busy_lcd()); IOCLR0 = (LCD_IOALL_MASK); IOSET0 = (LCD_D5); enable_lcd(); delay(10000); while(busy_lcd()); lcd_write_control(0x28); lcd_write_control(0x0C); lcd_write_control(0x06); lcd_write_control(0x01); lcd_write_control(0x0F); lcd_write_control(0x01); for (i=0;i<100000;i++); } //***************************** char busy_lcd(void) { unsigned long busy_status; unsigned int i; IODIR0 &= LCD_DATA_MASK; IOCLR0 = LCD_RS; IOSET0 = LCD_RW; IOSET0 = LCD_EN; for (i=0;i<1000;i++); busy_status = (IOPIN1 & 0x80000000); if(busy_status == 0x80000000) { IOCLR0 = LCD_EN; IOCLR0 = LCD_RW; IODIR0 |= LCD_IOALL_MASK; return 1; } else { IOCLR0 = LCD_EN; IOCLR0 = LCD_RW; IODIR0 |= LCD_IOALL_MASK; return 0; } } //****************************** void lcd_out_data4(unsigned char val) { IOCLR0 = (LCD_DATA_MASK); IOSET0 = (val<<20); } //********************************** void lcd_write_byte(unsigned char val) { lcd_out_data4((val>>4)&0x0F); enable_lcd(); lcd_out_data4(val&0x0F); enable_lcd(); delay(100000); // while(busy_lcd()); } //********************************** void lcd_write_control(unsigned char val) { IOCLR0 = LCD_RS; lcd_write_byte(val); } //********************************** void lcd_write_ascii(unsigned char c) { IOSET0 = LCD_RS; lcd_write_byte(c); } //******************************** void goto_cursor(unsigned char i) { i |= 0x80; lcd_write_control(i); } //******************************* void lcd_print(unsigned char* str) { int i; for (i=0;i<16 && str[i]!=0;i++) { lcd_write_ascii(str[i]); } } //****************************** void delay(unsigned long int count1) { while(count1 > 0) {count1--;} }
I will copy the other code in the below thread
