Lcd initialization
hi, guys I have a doubt regarding interfacing lcd to arm7.
I have an lpc2148 development board. This board did have a lcd interfacing example. I also have another program I got from internet. I see that the function to initialize the lcd are written in different ways in both the examples.
In the example I got with the board the "void lcd_init()" is little complex. But the other example I got from internet the has "void init_lcd( void )" written in a simple way.
I have edited and tried the codes in different ways and I see only the code I received with the board works.
I am new to ARM, but I don't think this should be correct, we should be able to make new codes. Hoping someone can understand my doubt.
CODE THAT CAME WITH THE DEVELOPMENT BOARD
#include <LPC214x.H>
#define  LCD_RS     (1<<10)
#define  LCD_RW     (1<<12)
#define  LCD_EN     (1<<13)
#define  LCD_D4     (1<<20)
#define  LCD_D5     (1<<21)
#define  LCD_D6     (1<<22)
#define  LCD_D7     (1<<23)
#define  LCD_DATA_MASK   (LCD_D7|LCD_D6|LCD_D5|LCD_D4)
#define  LCD_IOALL_MASK  (LCD_D7|LCD_D6|LCD_D5|LCD_D4|LCD_RS|LCD_EN|LCD_RW)
void enable_lcd(void)
  unsigned int i;
  IOSET0 = LCD_EN;
  for (i=0;i<400000;i++);
  IOCLR0 = LCD_EN;
void lcd_init()
  unsigned int i;
  PINSEL1  = 0x00000000;
  IODIR0 |= LCD_IOALL_MASK;
  for (i=0;i<1000;i++);
  IOCLR0 = (LCD_IOALL_MASK);
  IOSET0 = (LCD_D5|LCD_D4);
  enable_lcd();
  for (i=0;i<100;i++);
  enable_lcd();
  enable_lcd();
  delay(10000);
  while(busy_lcd());
  IOSET0 = (LCD_D5);
  enable_lcd();
  delay(10000);
  while(busy_lcd());
  lcd_write_control(0x28);
  lcd_write_control(0x0C);
  lcd_write_control(0x06);
  lcd_write_control(0x01);
  lcd_write_control(0x0F);
  for (i=0;i<100000;i++);
char busy_lcd(void)
  unsigned long busy_status;
  unsigned int i;
  IODIR0 &= LCD_DATA_MASK;
  IOCLR0 = LCD_RS;
  IOSET0 = LCD_RW;
  IOSET0 = LCD_EN;
  busy_status = (IOPIN1 & 0x80000000);
  if(busy_status == 0x80000000)
  IOCLR0 = LCD_EN;
        IOCLR0 = LCD_RW;
    return 1;
  else
    IOCLR0 = LCD_EN;
        IOCLR0 = LCD_RW;
    return 0;
void lcd_out_data4(unsigned char val)
IOCLR0 = (LCD_DATA_MASK);
IOSET0 = (val<<20);
void lcd_write_byte(unsigned char val)
  lcd_out_data4((val>>4)&0x0F);
  enable_lcd();
  lcd_out_data4(val&0x0F);
  enable_lcd();
  delay(100000);
 // while(busy_lcd());
void lcd_write_control(unsigned char val)
  IOCLR0 = LCD_RS;
  lcd_write_byte(val);
void lcd_write_ascii(unsigned char c)
  IOSET0 = LCD_RS;
  lcd_write_byte(c);
void goto_cursor(unsigned char i)
  i |= 0x80;
  lcd_write_control(i);
void lcd_print(unsigned char* str)
  int i;
  for (i=0;i<16 && str[i]!=0;i++)
     lcd_write_ascii(str[i]);
void delay(unsigned long int count1)
  while(count1 > 0) {count1--;}
I will copy the other code in the below thread
  • THE OTHER EXAMPLE here i see the initialization of the lcd is done in a very simple way
    #include "lcd.h"
    #define LCD_DATA_DIR IO0DIR
    #define LCD_DATA_SET IO0SET
    #define LCD_DATA_CLR IO0CLR
    #define LCD_CTRL_DIR IO0DIR
    #define LCD_CTRL_SET IO0SET
    #define LCD_CTRL_CLR IO0CLR
    #define LCDRS (1 << 10)
    #define LCDRW (1 << 12)
    #define LCDEN (1 << 13)
    #define LCD_D4 (1 << 20)
    #define LCD_D5 (1 << 21)
    #define LCD_D6 (1 << 22)
    #define LCD_D7 (1 << 23)
    #define LCD_DATA_MASK (LCD_D4 | LCD_D5 | LCD_D6 | LCD_D7)
    #define LCD_BUSY_FLAG LCD_D7
    void delay(int count)
    { int j=0,i=0;
    for(j=0;j<count;j++) { /* At 60Mhz, the below loop introduces delay of 10 us */ for(i=0;i<35;i++); }
    void wait_lcd( void )
    { LCD_CTRL_CLR |= LCDRS; LCD_CTRL_SET |= LCDRW |LCDEN; while(IO0PIN & LCD_BUSY_FLAG);
    LCD_CTRL_CLR |= LCDEN | LCDRW; LCD_DATA_DIR |= LCD_DATA_MASK;
    delay(100);
    void lcd_command_write( unsigned char command )
    { unsigned char temp=0; unsigned int temp1=0;
    temp=command; temp=(temp>>4)&0x0F; temp1=(temp<<20)&LCD_DATA_MASK;
    LCD_CTRL_CLR = LCDRS; LCD_CTRL_SET = LCDEN; LCD_DATA_CLR = LCD_DATA_MASK; LCD_DATA_SET = temp1; delay(10000); LCD_CTRL_CLR = LCDEN;
    temp=command; temp&=0x0F; temp1=(temp<<20)&LCD_DATA_MASK; delay(100*2);
    LCD_CTRL_CLR |= LCDRS; LCD_CTRL_SET |= LCDEN; LCD_DATA_CLR = LCD_DATA_MASK; LCD_DATA_SET = temp1; delay(10000); LCD_CTRL_CLR |= LCDEN; wait_lcd();
    void set_lcd_port_output( void )
    { LCD_CTRL_DIR |= ( LCDEN | LCDRS | LCDRW ); LCD_CTRL_CLR |= ( LCDEN | LCDRS | LCDRW ); LCD_DATA_DIR |= LCD_DATA_MASK;
    void lcd_clear( void)
    { lcd_command_write( 0x01 );
    int lcd_gotoxy( unsigned int x, unsigned int y)
    { int retval = 0;
    if( (x > 1) && (y > 15) ) { retval = -1; } else { if( x == 0 ) { lcd_command_write( 0x80 + y ); } else if( x==1 ){ lcd_command_write( 0xC0 + y ); } } return retval;
    void lcd_data_write( unsigned char data )
    temp=data; temp=(temp>>4)&0x0F; temp1=(temp<<20)&LCD_DATA_MASK;
    LCD_CTRL_SET |= LCDEN|LCDRS; LCD_DATA_CLR = LCD_DATA_MASK; LCD_DATA_SET = temp1; LCD_CTRL_CLR |= LCDEN;
    temp=data; temp&=0x0F; temp1=(temp<<20)&LCD_DATA_MASK;
    LCD_CTRL_SET |= LCDEN|LCDRS; LCD_DATA_CLR = LCD_DATA_MASK; LCD_DATA_SET = temp1; LCD_CTRL_CLR |= LCDEN; wait_lcd();
    void lcd_putchar( int c )
    { lcd_data_write( c );
    void lcd_putstring( unsigned char line, char *string )
    { unsigned char len = MAX_CHAR_IN_ONE_LINE;
    lcd_gotoxy( line, 0 ); while(*string != '\0' && len--) { lcd_putchar( *string ); string++; }
    void lcd_backlight_on()
    { LCD_BACK_LIGHT_DIR |= LCD_BACKLIGHT; LCD_BACK_LIGHT_SET |= LCD_BACKLIGHT;
    void turn_off_lcd_back_light_cb(void)
    { LCD_BACK_LIGHT_DIR |= LCD_BACKLIGHT; LCD_BACK_LIGHT_CLR |= LCD_BACKLIGHT;
    { set_lcd_port_output(); delay(100*100); lcd_command_write(0x28); lcd_clear() ; lcd_command_write(0x02); lcd_command_write(0x06); lcd_command_write(0x0C) ; lcd_gotoxy(0, 0); lcd_clear();
    } I have copied only the lcd file, please let me know, if I need to explain anything
    #include "lcd.h"
    { int j=0,i=0;
    delay(100);
    { int retval = 0;
