I used FlashFS example and RTX_CAN example in RL folder examples in keil uvision and combined them together.But less than one minute I face with Runtime error and in debug mode the code climb to os_error function in RTX_Conf_CM.c.
For playing .Wave file i must to modify RTX_Conf_CM.c as below:
#ifndef OS_TASKCNT #define OS_TASKCNT 26 #endif #ifndef OS_PRIVCNT #define OS_PRIVCNT 1 #endif #ifndef OS_STKSIZE #define OS_STKSIZE 75 #endif #ifndef OS_STKCHECK #define OS_STKCHECK 1 #endif #ifndef OS_RUNPRIV #define OS_RUNPRIV 1 #endif #ifndef OS_CLOCK #define OS_CLOCK 100000000 #endif #ifndef OS_TICK #define OS_TICK 15 #endif #ifndef OS_ROBIN #define OS_ROBIN 1 #endif #ifndef OS_ROBINTOUT #define OS_ROBINTOUT 10 #endif #ifndef OS_TIMERCNT #define OS_TIMERCNT 0 #endif #ifndef OS_FIFOSZ #define OS_FIFOSZ 16 #endif #ifndef OS_MUTEXCNT #define OS_MUTEXCNT 500 #endif
after for example 20s or 30s or more trying for fclose() command i face to runtime error. Maybe the processor has problem with fclose() command .
this is the code in my Receive data funcion:
__task void loop_1(void){ for(;;){ os_dly_wait(1); //os_mut_wait(&mut_IO, 0xffff); //os_mut_wait(&mut_CAN, 0xffff); /*---------------------------Music is played-----------------------------------------*/ if(/*!(Rx1_val&1<<FAST_REL)&&*/music_start==0) { initcard: tsk_lock(); if(finit () == 0) { tsk_unlock (); } else{ tsk_unlock (); os_dly_wait(50000); goto initcard; } next1="M:\\_1.wav"; // os_mut_wait(mut_IO, 0xffff); os_dly_wait(1000); tsk_lock (); fp = fopen (next1,"rb"); tsk_unlock (); if (fp == NULL) { os_dly_wait(50000); goto initcard; } music_start=1; } if(music_start==1) { file_read_bac=feof(fp); if(!file_read_bac) { tsk_lock (); ch=fgetc(fp); tsk_unlock (); LPC_DAC->DACR= (1024/255)*ch<<6|0x10000; } else { rewind(fp); closing: tsk_lock(); if (!fclose (fp)) { tsk_unlock (); } else if(fclose (fp)==EOF) { tsk_unlock (); os_dly_wait(50000); goto closing; } os_dly_wait(1000); flushing: tsk_lock(); if (fflush (fp)) { tsk_unlock (); os_dly_wait(50000); goto flushing; } else tsk_unlock (); music_start=0; } } } }
This is my CAN task:
__task void task_rece_CAN (void) { CAN_msg msg_rece; for (;;) { /* When message arrives store received value to global variable Rx_val */ os_mut_wait (&mut_CAN, 0xffff); if (CAN_receive (1, &msg_rece, 0xFFFF) == CAN_OK) { //os_evt_clr(0x0001,t_task_send_CAN); // os_mut_wait(mut_IO, 0xffff); Rx_val = msg_rece.data[0]; Rx1_val = msg_rece.data[1]; Rx2_val = msg_rece.data[2]; Ext1 = msg_rece.data[3]; Ext2 = msg_rece.data[4]; Rx3_val = msg_rece.data[5];//sensors Rx4_val = msg_rece.data[6];//init_elevator mainboard_receive_frame(); os_evt_set(0x0001,t_task_send_CAN); } os_mut_release (&mut_CAN); } }
when i disable CAN task the sd card reading is fine but when i enable both task i face with Runtime error .the problem is on fclose() or fopen() I think I have problem with SPI function.because FlashFS example is not RTX. What should i do?is it any Flash Fs example which can work with RTX?or can you help me to improve my code?
