Dear Board
Keil crashes when i press settings in debugging window with STlink plugged in.
im using STM32 board, and when i use "stlink utility" the standalone software works fine without issue. i can read and see the memory of my stm32f103 board.
but why it is not working with keil debugging or flashing ??
3 weeks back Keil and stlink were working fine and i tried blinkey and serial communicatoon all worked good.
Today morning i upgraded stlink firmware from V2.20 (or) V2.21 im not sure to --> V2.28. Thats it keil crashing started.
I have googled and found few informations from keil site and other sites rolling back to 2.27, 2.24 etc nothing worked. Keil keep on crashes.
i even searched for V2.20 firmware.. i dont find it anywhere in web. may be my search is not good.
im spending much time on fixing these tools instead of learning working with STM32.
Can anyone help me?
What version of Keil? You might want to have DLL and drivers contemporaneous with the ST-LINK firmware.
drive.google.com/open
If things were working why upgrade the firmware, the benefits are illusory?
Hi..
no success. thanks for your path. i have rolled back to 2.20 no success still.. :(
my keil uvision version is 5.23.0.0 Toolchain : MDK-Lite Version : 5.23 Target DLL : --> V2.07.0_KEIL
is it ok??
how im gona get out of this?? :(
Hello
I ve uninstalled and re-installed Keil and now everything is fine.
a new problem is appearing. Target device not found. need to find what could be the problem.
any idea?? please let me know.
thank you
