I guess it is not just a question Keil product, but I need your advice. I am using STM32f1 with CubeMX and keil mdk5. in my project i have to read muti channel ADC value ADC is in Scan conversion mode Enable, Number of conversion 2, Rank1 Channel Temperature sensor and Rank 2 Chane Vrefint.
while(1){ HAL_ADC_Start(&hadc); while(HAL_ADC_PollForConversion(&hadc,0) != HAL_OK); channel_1 = HAL_ADC_GetValue(&hadc); while(HAL_ADC_PollForConversion(&hadc,0) != HAL_OK); channel_2 = HAL_ADC_GetValue(&hadc); HAL_ADC_Stop(&hadc); }
Problem is booth call HAL_ADC_GetValue() retint value of Rank1 ti is voltage on Channel Temperature sensor. I can not figure out how to read value from next RANK 2
Thanks for help.
You are supposed to use DMA for multi-channel acquisition
In multi DMA is not possible use non DMA mode?
Sorry in multi channel ....
If you don't want to use DMA you have to reconfigure ADC for each channel and read one by one. In other case - you must use DMA to obtain data from more than one channel. DMA is easy, what's the problem using it?
My point is to have a precisely defined time of sampling individual channels. For example in time 0ms chamel1 in time 1ms chamel2 in time 5ms chamel3 etc.
I change my idea and I use DMA
As I remember ADC may give you interrupt after each conversion. Even when using DMA.
When using DMA, HAL_ADC_GetValue does not need to be included. You include HAL_ADC_Start_DMA (& hadc1, (uint32_t *) Add_Data, n); Where Add_Data-array. You remove the data with Add_Data [n]
