How to use a self created library and the default *.lib in Keil C ? and which and how to setup a default *.lib such as the following - c51s.lib ? c51L.lib ? c51c.lib ? ======================================= i have create a header file myfirst.h ======================================= #pragma SAVE #pragma REGPARMS extern char returndummychar(void); #pragma RESTORE ======================================== and the source code myfirst.c ======================================== char returndummychar(void) { return('a'); } ======================================== I compile the file and have myfirst.obj ======================================== lib51 create myfirst.lib lib51 add myfirst.obj to myfirst.lib ============================================ All the above steps are done. now, how to include the myfirst.lib in a new C project ?? Thank you very much !
You can try the method mentioned in http://www.keil.com/support/docs/634.htm. This artical is about how to use library functions. chao.
