When I try open Keil software, There is an error appears like R6002 floating point not loaded error. I dont know, how to fix this issue without uninstalling keil. Please someone help me in this. Thanks.
So if you don't think it's related to Keil support - do you then think it's related to other end-users of the product?
I think this is not related to Keil support. Because this error started appearing after installing one software. I tried uninstalling the same software, but no use. The error appears like below.
Microsoft Visual C++ Run time Library. Run Time Error! Program: C:\Keil4_6\UV4\UV4.exe R6002 - floating point support not loaded.
Is this error Keil support related?
Thanks.
Don't you think this sounds lika a Keil support issue? Notice the links on top and bottom of every page mentioning "Support"?
