Hello How can i define a variable or string in flash memory in keil mdk 5 ? Thanks.
Probably the same way you would in any version of the tools?
static const char foo[] = "I wish I'd read K&R, and other tomes more diligently";
Then again if you want it to actually be "variable", flash is probably not the desired location.
See also #pragma, attribute, AT, and assorted directives and scatter file options.
