I am using uVision 5. However sometimes, the toolbar pictures/icons are not correct for e.g. Translate tool has a picture same as that of "New" tool, "Build" tool has same as that of "Open" tool etc. Has anyone ever seen this problem in uVision?
It looks like the Windows registry got corrupted.
Please execute the menu command Window - Reset Windows to Defaults.
Does this solve the issue?
It solved the issue. Thanks
FYI this KB article also describes this issue:
http://www.keil.com/support/docs/3616.htm
Thank you your support. This problem is solved but old project cause the same problem.
Best regards.
